Date/Time: Sat, 21 Nov 2026 15:46:25 +0000
Time specific Pivot Points-Daily
View Count: 2734
| [2013-06-06 10:42:18] |
| tobi - Posts: 351 |
I'm aware, that the Pivot Points-Daily are calculated based on the Session Times used in Chart Settings. In forex trading often times traders like to look at Pivots based on different session times. 05:00 PM (NY-time) and 00:00 midnight (NY-time) Pivots are very popular. Therefore, would you please consider adding the possibility to add the Session Time on which the Pivots calculation should be based on in the Pivot Points-Daily study. That way, e.g. the study could be used twice on a chart with different settings. (In case this is relevant, the above is related to Formula Type 0) |
| [2013-06-07 09:12:13] |
| tobi - Posts: 351 |
Reason why I'm asking for this: FXtrek/IntelliChart is going out of business http://www.fxtrek.com/Misc/ The software had this commonly used feature. I do advertise for SC in a FX group where mainly IntelliChart has been used, since I'm 100% convinced of SC. Date Time Of Last Edit: 2013-06-07 09:13:02
| [2013-06-07 21:46:16] |
What you want to do is explained here: http://www.sierrachart.com/index.php?l=doc/helpdetails28.html#OverlayStudyDiffSessionTimes It is at the bottom of the page. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
