Date/Time: Sun, 22 Dec 2024 10:16:08 +0000
[User Discussion] - Recalculate
View Count: 955
[2015-06-11 16:01:59] |
User75519 - Posts: 15 |
I always have to hit recalculate for my studies to work properly
[2015-06-11 19:09:05] |
Are these your own custom studies? If so, it means there is a problem with how they are programmed.
[2015-06-11 23:53:02] |
It is a custom study from Trade29 which is the studies list. I am looking for a study for Divergence. Can you help me. thanks
[2015-06-12 02:36:24] |
Kiwi - Posts: 375 |
I did a function to periodically recalculate SC for someone with a similar issue. Take a look at: request for a very simple ACSIL study You might also let T29 know about the issue so that the basic problem can be fixed. Periodic recalcs are computationally expensive so its better to just fix the dll. Date Time Of Last Edit: 2015-06-12 02:38:03
[2015-06-12 16:23:07] |
Thank You very much. do you by any chance have a study of divergence. thanks again
