Date/Time: Sun, 22 Dec 2024 15:11:12 +0000
Data not flowing
View Count: 830
[2015-06-11 13:35:13] |
HalGE - Posts: 39 |
Today is Rollover day for many futures contracts and the data is not flowing I updated the ES NQ and YM contracts and the message in the chart is Waiting To Download Historical Data same message on all symbols I double checked all the symbols and it looks ok What could be wrong? |
[2015-06-11 13:52:46] |
HalGE - Posts: 39 |
Looking in the files I think I found the problem Using the Automatic Rollover method where I just Click Here and the pc sposed to do its thing...Found to many files named the same...so, I just tossed out what I didnt need and renamed what I wanted to keep and so far so good... |
[2015-06-11 18:48:22] |
OK let us know if you need more help. We see you are using the Sierra Chart Exchange Data Feed and the downloading of historical data should be very fast. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
