Date/Time: Sun, 22 Dec 2024 15:50:26 +0000
[User Discussion] - Number of contracts on chart
View Count: 923
[2015-06-11 05:36:17] |
User33743 - Posts: 83 |
hello, Is it possible to switch off number of contracts on chart? Option do not show profit/loss doesn't do that. |
Screenshot_4.png / V - Attached On 2015-06-11 05:35:36 UTC - Size: 111.13 KB - 418 views |
[2015-06-11 15:28:53] |
anyone know how to do that?
[2015-06-11 18:17:45] |
This is not supported and there are no plans for this.
