Date/Time: Sun, 08 Sep 2024 02:11:49 +0000
hide chart
View Count: 921
[2015-06-11 04:52:44] |
nicktrader - Posts: 699 |
I'd like to hide my chart in region 1 because I'd like to see the study of region 2 only. Is there a way? |
[2015-06-11 05:33:58] |
The general method is to reduce the height of that Chart Region to a minimum. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
