Date/Time: Sun, 22 Dec 2024 15:09:10 +0000
DAX back adjustment
View Count: 875
[2015-06-11 02:45:51] |
xRoads1 - Posts: 35 |
Does or are that plans for the The Sierra Chart Historical Data Service without a live account to support continuous contract back adjustment on the MDAX Index? I have the most current SC update and I can't get it to work. Thx.
[2015-06-11 04:34:53] |
What is the exact symbol? We need to know at least the first two characters of it. And confirm exactly what Global Settings >> Data/Trade Service Settings >> Service is set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-11 13:02:57] |
DM
[2015-06-11 13:05:20] |
SC Historical Data [data]
[2015-06-11 19:24:56] |
Update the symbol settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps The rollover settings have been set up for that symbol. Just go to the chart and select Chart >> Reload and Recalculate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
