Date/Time: Sun, 22 Dec 2024 15:16:49 +0000
Last Trade on Dom for Euro Futures Contract not changing correctly.
View Count: 1044
[2015-06-10 19:43:34] |
User650681 - Posts: 9 |
Hello Sierra, Using CTS feed. The Dom for last trade Euro Futures June Month does change correctly. It always shows 1 or 2 contracts traded not the real last trade. For instance when running the CTS along side it clearly shows the proper amount. Any thoughts as to why i am not seeing the right last trade? Thank you. Version 1261 |
[2015-06-10 19:51:23] |
Actually I notice it does this for any product i bring into the DOM. Only shows 1 or 2 lots for last trade.. |
[2015-06-10 23:44:16] |
Hello Sierra. I posted a screen shot if this helps. Last traded price is important as it indicates the size hitting the bid or offer. Thanks. |
Untitled.jpg / V - Attached On 2015-06-10 23:43:16 UTC - Size: 162.79 KB - 373 views |
[2015-06-11 04:48:18] |
What is the exact name of the market data column you have added to the Trade DOM through Global Settings >>Customize Trade DOM Columns. If this is the last trade volume/size and to make sure it is correct, you can simply go to Chart >> Open Time and Sales Window and verify that what you see matches the actual trade volume. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-11 08:15:45] |
I figured it out. I never saw the cumulative Last Size. Now it matches exactly to CTS time and sales ticker. The column i had in the center was Last size. Needed Cumulative Volume/size. What does Last Size track? I thought it was the total volume? So confusing... |
[2015-06-11 09:58:43] |
The last trade size is simply the volume of the actual last trade itself.
