Date/Time: Sun, 22 Dec 2024 15:14:53 +0000
VbP
View Count: 1067
[2015-06-10 19:21:20]
User300883 - Posts: 7
I need advice, whether it is to do the following:
1. "clipped" volume profile always max. Left, although counts from a certain time?
2. I have two graphs in one window. On the second chart I will not turn VBP and VWAP. Other indicators so what's the problem?
3. How do the crosshair was active right after "run over" to another chart.
Thank you.
[2015-06-11 05:06:51]
1. This is not clear for us. Can you provide a drawing.
2. These two studies can only be applied to the main price graph. There is no other possibility at all and this simply is not possible to support.
3. You will have to deactivate this tool first before going to another chart. Also make sure Tools >> Global Cursor On is disabled.
[2015-06-11 09:33:48]
Thank you for answer.
A to point 1.
I need to make the current VBP was placed on the left. It is drawn from the time of 15:30, but I need it "fixed" on the left. No time to 15:30.
imageVbP.jpg / V - Attached On 2015-06-11 09:33:14 UTC - Size: 293.94 KB - 368 views
[2015-06-11 11:05:46]
OK we understand. It is not possible to align a Volume Profile to the left like this. Only to the right side.
[2015-06-11 11:43:23]
Ok
