Date/Time: Fri, 20 Nov 2026 05:28:54 +0000
Organize windows within chartbook question
View Count: 1492
| [2015-06-10 19:02:14] |
| rhovega - Posts: 279 |
Is it possible to determine/affect the order in which the charts will be arranged when arranging charts by using "Tile Horizontally" / "Tile Vertically"? Every time I click on Tile Horizontally Sierra Charts arranges chart windows in a different order. It forces me to manually put CL on the top left corner, NG on the bottom left corner, and so on with my six main instruments. I have looked for a pattern behind the order (such as chart #) but I have found none. Thank you. |
| [2015-06-10 20:29:15] |
No it is not. Those commands are actually implemented by the Windows operating system. Longer-term this functionality will be built by Sierra Chart and the order will be consistent. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
