Date/Time: Sun, 08 Sep 2024 02:01:23 +0000
Feature Suggestion: Text Column in TradeDOM
View Count: 784
[2015-06-10 17:43:38] |
jwick - Posts: 142 |
Suggestion: A column in the trade dom where you can write text for a specific price level. This'd be very flexible for various trading strategies where you want to simply mark off important levels to pay attention to and maybe label them so you know why they're important.
[2015-06-10 17:58:07] |
On a regular chart you can add a Horizontal Line and set the text on that: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ModifyText Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-10 18:00:34] |
hah learn something new every time. I didn't realize I could Copy Chart drawings onto a tradeDOM the same way I can onto a chart. Thanks!
