Date/Time: Sun, 08 Sep 2024 02:17:45 +0000
Time Line Problem
View Count: 745
[2015-06-10 15:02:48] |
Crtfyd - Posts: 278 |
vs 1259 There's a problem with the "Time Line" study. When I go to "Apply/Ok" the TEXT disappears. I enter all of my desired data including "Yes" to "Display Custom Label" Everything is verified by my clicking "Apply" and "OK" in the Studies Window. Everything shows as its suppose to. BUT, as soon as I click "Apply" OR "OK" in the "Chart Studies" window to complete the process, the Label disappears. *NOTE: This ONLY happens when dealing with the TEXT label, otherwise the Time line will display. See attached. 1st pic is all settings set. 2nd pic is after clicked "Apply", you can see it displays. 3rd pic is after clicked "OK/Apply", you can see TEXT disappears. Date Time Of Last Edit: 2015-06-10 15:03:16
[2015-06-10 17:37:42] |
We are not able to reproduce this problem. But we will have a look at the code to make sure everything is OK.
