Date/Time: Sun, 08 Sep 2024 01:59:52 +0000
HI SUPPORT,
View Count: 807
[2015-06-10 13:22:23] |
User53765 - Posts: 66 |
I NOTICED I CANNOT ADJUST THE SIZE OF THE MOVING ARROW ON THE TPO PROFILE CHART AND WAS JUST WONDERING WHY THIS FUNCTION IS NOT ENABLED ALTHOUGH EVERYTHING SEEMS TECHNICALLY POSSIBLE. PLEASE LET ME KNOW IF IM DOING SOMETHING WRONG OR IF THE ARROW CANNOT BE CHANGED IN SIZE. THANKS IN ADVANCE. |
[2015-06-10 17:37:49] |
This is not adjustable.
