Date/Time: Sun, 08 Sep 2024 02:14:57 +0000
changing time frames on a chart with chart trading on
View Count: 744
[2015-06-10 04:25:07] |
Trader Ra - Posts: 87 |
is it safe to change time frames on an 'execution' chart that has active chart trading, the DOM and attached orders etc or would it be better to have separate charts setup instead? thanks.
[2015-06-10 05:49:32] |
This is perfectly safe.
