Date/Time: Sun, 08 Sep 2024 02:12:07 +0000
Square of 9
View Count: 1002
[2015-06-09 22:48:18] |
Crtfyd - Posts: 278 |
vs 1259 Square of 9 does not round to nearest tic on chart. |
[2015-06-10 18:03:33] |
This study never supported rounding to the nearest tick.
[2015-06-10 19:28:52] |
I recall a previous version several years back did. Regardless, I just set the "Value Format" to 1/4. That helps with the arduous task of converting 2165.77 to 2165.75...therefore reading 2165 3/4. I jest of course, but sometimes in a quick moving/stop running market, a tic makes a difference. Harder to do quickly with other things going on when say a 2165.36 is ?? (.25 or .50 Maybe a future version will include this because most other studies already round to the tic. ;P Regards |
