Date/Time: Sat, 04 Jul 2026 07:56:39 +0000
Increasing volume indication
View Count: 1405
| [2015-06-09 21:38:33] |
| User43999 - Posts: 3 |
Hello… Is there any way with using the Volume study to show if a bar has increasing volume over the previous bar? For instance, using a 5minute chart, the volume for 0945 is 5000 and the volume for 0950 is 5050 which is greater than the 0945 volume. I use a specific color for up and down and use the bar as the representation. Is there a way to have an arrow above the volume bar that displays when compared to the previous bar that volume is higher? Thank you! |
| [2015-06-11 05:27:25] |
Look at the "Color Bar Based on Alert Condition" study.
