Date/Time: Tue, 04 Aug 2026 06:42:54 +0000
How to disable Log messge
View Count: 1245
| [2015-06-09 17:54:32] |
| GreyLock58 - Posts: 173 |
I can hide the log message when the SC program is up and running. My issue is that the log messages come back up maximized whenever my windows 7 computer come out of sleep. This gets old with multiple SC programs running. I need my computer to go to sleep and wake up several times a day. Is there any remedy...can one be found?
Date Time Of Last Edit: 2015-06-09 17:59:58
| [2015-06-09 20:29:51] |
Yes, we did solve this. The particular message that indicates that the system has come out of sleep mode will no longer open the Message Log. Update to the latest prerelease. We also recommend avoid using sleep. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
