Date/Time: Sun, 22 Dec 2024 16:29:08 +0000
PnF bars shown as 54 tick reversal ohlc bars not populating properly
View Count: 1028
[2015-06-09 16:09:09]
User118072 - Posts: 6
Typically, a 54 tick PnF bar plotted as an ohlc bar will be quite long in length. However, there are many random 1, 2, 3 etc tick bars that should be much longer being plotted on my chart. Consequently, any study done on bars is erroneous.
I have installed same bars on my office computer, which works perfectly.
Don't know if it is a factor, but I am getting message:AT usage time has ended, to purchase more time, press help and add usage credit and restart AT.
Please let me know what I can do to correct these bars.
Thank you in advance for your help.
Gary Hurlbut
[2015-06-09 16:45:17]
We recommend using the Reversal Bar setting in Chart >> Chart Settings. It is documented here:
https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#ReversalBar
Also in Chart >> Chart Settings, uncheck New Bar at Session Start
In regards to the usage time has ended message, restart Sierra Chart.
Date Time Of Last Edit: 2015-06-09 16:45:54
