Date/Time: Fri, 18 Oct 2024 06:32:03 +0000
how to get more history on 1hr chart?
View Count: 837
[2015-06-09 13:15:59] |
User677861 - Posts: 10 |
I am trying to load more bars on the 1hr chart but it only seems to show the last 4-5 weeks. How can I increase this? |
[2015-06-09 16:42:22] |
Refer to this section here for help with this: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#DownloadingViewingMoreHistoricalIntradayData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-10 01:14:05] |
Hi This seems like it downloads data but when I drag the date at the bottom of the chart, it wll ot expand it, it only contracts/zooms in. Screenshot attached. Date Time Of Last Edit: 2015-06-10 01:14:17
Untitled.png / V - Attached On 2015-06-10 01:13:56 UTC - Size: 128.66 KB - 292 views |
[2015-06-10 01:24:06] |
You need to drag the scrollbar box towards the left to go back in time. We also see your Sierra Chart account is expired. Make sure you are logged into this Support Board with the account you use Sierra Chart with. You can do that through Help >> Support Board. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-10 01:28:25
[2015-06-10 01:32:19] |
when i do that it changes the volume by price peaks and troughs. Shouldn't they stay the same or is it only doing it on visible bars? |
[2015-06-10 02:15:16] |
Yes it is because the Volume by Price study is set to Visible Bars. Over what time period do you want the volume profiles based on?
