Date/Time: Sun, 22 Dec 2024 16:28:22 +0000
issue with XC-201512-CBOT intraday data
View Count: 819
[2015-06-09 10:51:49] |
User297263 - Posts: 1 |
Hi I couldn't obtain intraday data/charts for cbot mini corn futures for XC-201512/ It's not an issue for historical chart but for intraday. Date Time Of Last Edit: 2015-06-09 10:53:13
[2015-06-09 11:00:21] |
This is now solved. Go to the chart and select Edit >>Delete All Data and Download.
