Date/Time: Sun, 08 Sep 2024 02:01:02 +0000
Size of letters
View Count: 844
[2015-06-08 18:57:03] |
julian pineda - Posts: 60 |
it is posible to make those letters and numbers bigger? |
![]() Attachment Deleted. |
[2015-06-08 21:17:15] |
Yes. Adjust the Size setting for the Subgraph on the Subgraphs tab in the Study Settings window for that study.
[2015-06-09 15:38:24] |
it wont even let me touch the Width/size button
[2015-06-09 17:03:16] |
OK we did not understand what you are referring to. Please be specific. If you referring to the standard chart text, which includes the price scale, you can change the font size through Graphics Settings. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-10 14:01:05] |
I want to know if i can change the font, the size of those numbers. if i go to Graphics Settings, i cant change anything as you can see in the pics
[2015-06-10 17:35:26] |
You can change the font on the first tab of the Graphics Settings window, in the version you are running. When you change the font for the chart, all text on the chart will change except for some custom text from studies. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
