Date/Time: Fri, 03 Jan 2025 16:05:41 +0000
progressive vbp
View Count: 923
[2015-06-08 18:30:24] |
User439550 - Posts: 12 |
Is it possible to plot the progress of POC, VA etc. in a given period. I'd like to see POC and VA's in motion as opposed to the end of the period depiction of what the values were.
[2015-06-08 21:16:42] |
Yes you can. Are you using the Volume by Price or the Volume Value Area Lines study?
[2015-06-08 23:08:48] |
would like to do some backtesting with both of them, thanks
[2015-06-09 05:19:49] |
We have prepared documentation for how to do this here: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.html#CalculatingDisplayingDevelopingPOCVALHLLines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-09 12:28:04] |
Thank you!
