Date/Time: Mon, 16 Sep 2024 19:09:19 +0000
chart
View Count: 2504
[2016-01-22 18:48:46] |
Regarding post #24, this is now solved. Any time you re-download the data in the Intraday chart when using the Sierra Chart Exchange Data Feed for the CME symbols, you will get exactly the same amount of volume. Will be doing an update this evening for the NYMEX, CBOT and COMEX. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-29 08:27:26] |
Just confirming that the problem of the small inconsistency when re-downloading data that you could see with CME futures symbols has been solved. Please let us know if you still see any further problem. And also confirm that it is solved. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-04 10:36:34] |
User67633 - Posts: 14 |
Hi, yes,all my problems seem to be solved.I defenetly will stick to sc's own data feed in the future. I'm just wondering,what broker/clearing firm do you think is the most reliable to use to daytrade es on my own sc platform? I know it is not your job to recommend anything,but after working and having server problems through gain/oec and transact, i would consider to try something more stable next time - if there was any. Private opinion's welcome of course. |
[2016-02-04 11:23:22] |
This is good. We can only give you a recommendation as to what we call the trading platform service. You can consider TT, CQG or CTS. They are all here: https://www.sierrachart.com/index.php?page=doc/Data.php There is also Rithmic, but there are are technical aspects of Rithmic that we are not totally comfortable with but this is our opinion only. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
