Date/Time: Sun, 22 Dec 2024 15:58:36 +0000
Real time S&P 500 data
View Count: 1486
[2015-06-08 14:26:04] |
User69487 - Posts: 21 |
I have package 5 and added the $SPX intraday chart however I do not see real time data for the index, it seems to update sparingly.
[2015-06-08 17:09:33] |
For information about accessing the data for that particular symbol, refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CashIndexes You need to instead use the symbols listed under File >> Find Symbol >> IB Indexes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
