Date/Time: Sun, 22 Dec 2024 16:52:27 +0000
Filtering volume doesn't allow Study/price overlay to plot bars
View Count: 1143
[2015-06-08 10:30:20] |
User11942 - Posts: 298 |
Hello SC team, I'm trying to set a chart up in a way that I could see only certain trades but with regular bars still plotting on it. I'm using Number bars study to visualize trades I want to see and Study/price overlay to plot regular bars in the same region. On the main chart (where Number bars study is running) I set volume filter on "Advanced settings 2" tab to a certain value and a check-box "Filter trade completely" is on, "Include columns with no data" is also on. There are no any filters set on the Study/price overlay source chart. As a result it works perfectly with historical data but doesn't work with real-time feed (probably b/c the Volume filter awaits the threshold to be reached). Please see screenshots attached. What did I set wrong? If all setting are correct then the question is how can I achieve my target? I also attached my chartbook herein. Thanks.
Date Time Of Last Edit: 2015-06-08 12:08:48
Private File Private File Private File |
