Date/Time: Sun, 22 Dec 2024 16:34:57 +0000
Renko bar not update
View Count: 806
[2015-06-08 01:39:12] |
User494576 - Posts: 2 |
Renko bar does not update in my chart in some currency pairs. Current price was shown in right ruler bar but the last bar's high/low is different from current price (see attachment). Please advise. Thanks.
chart error.jpg / V - Attached On 2015-06-08 01:36:02 UTC - Size: 68.47 KB - 332 views |
[2015-06-08 07:32:26] |
Refer to help topic 3 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails3.html We recommend setting the bars to a fixed amount of time like 10 minutes and see if you still have the problem. Let us know what happens when you do this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
