Date/Time: Sun, 22 Dec 2024 16:26:31 +0000
More history for Renko charts
View Count: 1314
[2015-06-07 22:11:19] |
arrow - Posts: 52 |
Will there be or is there a way to get more historical data for Renko bar charts? As of right now I'm getting about 30 days. This doesn't allow for a Renko bar much bigger then 20 ticks. |
[2015-06-08 17:40:58] |
Yes. Follow the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#DownloadingViewingMoreHistoricalIntradayData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
