Date/Time: Sun, 08 Sep 2024 02:03:04 +0000
Auto Retracement study for tickchart
View Count: 925
[2015-06-07 14:12:50] |
nicktrader - Posts: 699 |
Is it also possible to use this study for tickchart? There is only the option "time period unit"
[2015-06-08 17:54:56] |
Yes it will work on chart bars which are based upon a number of trades per bar.
[2015-06-09 03:34:14] |
As you can see in the attached file it do not work in every case. Each candle gives back the 55% Level - shown with a dotted line - in some cases it gives back the correct result but in other completely wrong because 55% Level is shown outside of the candles. Date Time Of Last Edit: 2015-06-09 03:35:08
[2015-06-09 04:02:30] |
We did not realize you had set the study to a 1 minute timeframe. Obviously that will not work reliably. Please understand how the calculations are done which are documented and the data that you are working with to come to a conclusion as to what the result would be. You are in a better position to determine what will work and what will not work. It is hard for us to make that determination since we do not know the settings you are using and we do not know the time frame per bar. Obviously with 1 minute timeframe for this study, you should probably be working with chart bars that are something like a fixed 5 seconds per bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-09 07:46:32
[2015-06-09 10:14:15] |
... or you offer additional in the "Time Period Unit" ==>> by Bar
[2015-06-11 05:28:33] |
This is difficult to implement this with how that study is currently designed.
