Date/Time: Sun, 22 Dec 2024 16:34:32 +0000
Use IB market data in SC
View Count: 846
[2015-06-06 21:37:29] |
TraderTom - Posts: 25 |
Can I look at the same data from Interactive Brokers I use in their charts in Sierra Charts? I would like to use SC tools with stock data from IB.
[2015-06-07 00:28:09] |
Yes you can. Here are set up instructions: http://www.sierrachart.com/index.php?page=doc/IB.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
