Date/Time: Sun, 22 Dec 2024 15:56:10 +0000
Drawing plotted from another chart covering price
View Count: 820
[2015-06-06 18:20:29] |
User623839 - Posts: 108 |
When I copy a drawing from a different chart, can I have it plot underneath price or even better plot underneath everything. I'm talking about the Horizontal Line specifically. I'm using it to plot Support and Resistance areas from another chart. I use a thicker horizontal line for Zones and it covers price once copied(pic attached)
Date Time Of Last Edit: 2015-06-06 18:21:24
Screen Shot 06-06-15 at 01.17 PM.PNG / V - Attached On 2015-06-06 18:18:52 UTC - Size: 16.83 KB - 340 views |
[2015-06-06 19:04:37] |
Or what about adding a check mark box for "Draw Under Price"
Screen Shot 06-06-15 at 02.02 PM.PNG / V - Attached On 2015-06-06 19:04:20 UTC - Size: 16.6 KB - 305 views |
[2015-06-07 21:13:46] |
There are options for controlling this in Chart Settings. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DisplayOrder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
