Date/Time: Fri, 13 Nov 2026 11:00:07 +0000
File with trade activity
View Count: 1178
[2015-06-05 18:46:58]
rhovega - Posts: 279
I run 2 instances of Sierra, one for charting, another for DOMs. The charting instance freezes every now and then (btw, it freezes on an i7 quadcore 4790k with 32gb of RAM and nothing but SC running on it). Therefore I had to move the DOMs to another instance. As a consequence, I can't see the fills on my chartbooks anymore.
Is there a file I could copy from the DOMs instance folder to the charting instance folder that would allow me to see the fills on the charting instance? I have tried copying TradeActivityLog.dat but it did not work.
Hope my question is clear.
[2015-06-05 21:02:16]
Yes. This is the TradeActivityLog.dat file. When you copy it over to another instance, that destination instance must not be running.
