Date/Time: Sun, 22 Dec 2024 16:04:18 +0000
Pricing question
View Count: 747
[2015-06-05 15:27:58] |
bookert4 - Posts: 56 |
Hello Support- I am shutting down operations from Jul to Aug, therefore, I will not be paying for a renewal until then. When I come back in September, will I be able to re activate my account simply by logging in and paying ? Also, I would like to not pay the exchange fees as well, can I do this? Thank you. |
[2015-06-05 16:57:43] |
Yes. This will work fine. Go to this page and deactivate the data feed, so you will not be billed for it or the exchange fees: https://www.sierrachart.com/usercp.php?page=MarketDataFeedFeatures When you deactivate the data feed, it will remain active until the end of this month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
