Date/Time: Sun, 22 Dec 2024 16:17:38 +0000
automatic rearm alert?
View Count: 933
[2015-06-05 13:51:07] |
User471252 - Posts: 1 |
I like to have an alert for Low or High Ticks. -750, 750 levels. After being triggered I have to go back into my manager and rearm. How can I create an alert for these where they automatically rearm themselves? Do I have to create a custom code? :/ Any tips appreciated. Seems simple, but out of ideas to make it happend. Thank you in advance! Matt |
[2015-06-05 16:52:15] |
So are you setting up what is called a Symbol Alert? That is not the best choice for this. It would be best to set up a Simple Alert on the chart itself. Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html The particular example you would want to work with is example number 12 here: https://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html#FormulaExamples Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
