Date/Time: Sun, 22 Dec 2024 16:45:17 +0000
tal
View Count: 847
[2015-06-05 13:16:15] |
User63439 - Posts: 83 |
hi there, my tal shows a trade thats closed but shown as still open. sierra wasnt running when the trade got stopped out. is there a way to correct this (maybe manually)? |
[2015-06-05 17:20:30] |
You can manually insert the order fill into the Trade Activity Log. The command is Edit >> Insert Trade Activity Entry. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php#MenuCommands Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
