Date/Time: Fri, 18 Oct 2024 06:34:38 +0000
Orders and Trades price visibility
View Count: 995
[2015-06-05 12:57:51] |
User742670 - Posts: 43 |
Dear Engineers, How can I disable the price shown in the chart after I enter and get out of the position? I just want to have the ability to see the lines of trades I have done.. See screen shot |
sierra.jpg / V - Attached On 2015-06-05 12:57:39 UTC - Size: 71.76 KB - 373 views |
[2015-06-05 16:55:31] |
You need to disable Trade >> Show Order Fills. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#DisplayingOrderFills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-08 08:38:45] |
Hello, Thanks for the reply..but my question was how can I disable the price where the trade was executed and closed? I just want to see the lines... See screen shot what I mean... |
Just tradelines.jpg / V - Attached On 2015-06-08 08:37:13 UTC - Size: 137.8 KB - 310 views |
[2015-06-08 16:19:09] |
So you do not want to see the Fill Marker arrows? Those cannot be removed and still see the connecting lines.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-08 16:19:18
[2015-06-10 10:34:15] |
Hello, No I just want to see the arrows and the lines not the price in the square as I posted in the last picture.. |
[2015-06-10 17:29:03] |
Therefore you just need to uncheck Global Settings >> Chart Trade Settings >> Order Fills >> Display Fill Text.
[2015-06-11 08:40:09] |
Many thanks!!Sierra has so many good features and settings but its sometimes very hard to find it! :-)
