Date/Time: Sun, 22 Dec 2024 16:31:48 +0000
Trouble to download new version
View Count: 859
[2015-06-05 05:48:15] |
User025842 - Posts: 13 |
Hi Guys I tried to install new 1261 ver. but not succeeded.Cleaned browser,cleaned all custom and user contr.studies from the charts,and Data files,study coll,cleaned downloads. Trying to download pre release 1261 gives me Error,then I wait,press Ignore,download is running,finishing,everything O'K, but on Help > About it is the same 1246 ver..It's never happened to me before. I run out of clues ,please advise me what to try ? Thank you, Isaac |
[2015-06-05 08:12:34] |
Select Help >> Download Current Version. Wait five minutes and then select the last 10 lines of the Message Log and press Copy Selection and paste them here. Here are general instructions to work with the Message Log: https://www.sierrachart.com/index.php?page=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-05 13:18:23] |
On logs ,Error loading custom studie dll,scan abvdt_v3dll,delete from data,and crossover marker error is b/c I now cannot open Advanced Studies. Software version: 1246 | 2015-06-05 09:03:56 Uses Old Spreadsheets | 2015-06-05 09:03:56 Enabled for: Advanced Features. | 2015-06-05 09:03:56 Enabled for: Sierra Chart Historical Data Service. | 2015-06-05 09:03:56 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-06-05 09:03:56 Active service: AMP/TTNet | 2015-06-05 09:03:56 Data/Trade Service Settings automatically set. | 2015-06-05 09:03:56 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-06-05 09:03:56 2015-06-05 09:03:56 Local computer clock time | 2015-06-05 09:03:56 2015-06-05 13:03:56 GMT time | 2015-06-05 09:03:56 2015-06-05 09:03:56 Time zone adjusted time | 2015-06-05 09:03:56 Time difference to server time: 18 seconds. | 2015-06-05 09:03:56 Program path: C:\SierraChart\ | 2015-06-05 09:03:56 Data Files path: C:\SierraChart\Data\ | 2015-06-05 09:03:56 OS Version Number: 6.1 | 2015-06-05 09:03:56 Locale Information: C | 2015-06-05 09:03:56 Checking for new symbol settings for tt | 2015-06-05 09:03:56 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-06-05 09:03:56 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-06-05 09:03:56 Symbol settings are up-to-date for tt | 2015-06-05 09:03:56 Files to Open on Start up | Opening file: Chartbook1.cht | 2015-06-05 09:03:59 Error loading custom studies DLL: C:\SierraChart\Data\StudyCrossMarker.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:03:59 * Error loading custom studies DLL: C:\SierraChart\Data\StudyCrossMarker.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:03:59 * Error loading custom studies DLL: C:\SierraChart\Data\scanABVDT_b3.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:03:59 * Error loading custom studies DLL: C:\SierraChart\Data\scanABVDT_b3.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:03:59 * Date rule based rollover from YM-201506-CBOT to next contract occurs at 2015-06-11. | 2015-06-05 09:03:59 Checking Intraday data file for symbol YM-201506-CBOT for the date range from 2015-03-12 to 0. | 2015-06-05 09:03:59 YM-201506-CBOT [C] 1500 Trades #1 | Symbols used for continuous contract chart: | 2015-06-05 09:03:59 YM-201506-CBOT | 2015-06-05 09:03:59 Error loading custom studies DLL: C:\SierraChart\Data\StudyCrossMarker.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:03:59 * Error loading custom studies DLL: C:\SierraChart\Data\StudyCrossMarker.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:03:59 * Error loading custom studies DLL: C:\SierraChart\Data\scanABVDT_b3.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:03:59 * Error loading custom studies DLL: C:\SierraChart\Data\scanABVDT_b3.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:03:59 * Intraday data recording state for symbol YM-201506-CBOT is set to download pending. | 2015-06-05 09:03:59 HD Request # 2 | Downloading Intraday chart data for YM-201506-CBOT to the file YM-201506-CBOT.scid. Service: ttamp | 2015-06-05 09:03:59 HD Request # 2 | Download start Date-Time: 2015-06-05 09:03:51.0 | 2015-06-05 09:03:59 HD Request # 2 | Using server: ttamp.sierracharts.com port 10149 | 2015-06-05 09:03:59 Intraday data recording state for symbol NTCK-NYSE is set to download pending. | 2015-06-05 09:03:59 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-06-05 09:03:59 Socket (2) | Connected. | 2015-06-05 09:03:59 HD Request # 2 | Sending historical data logon request message. | 2015-06-05 09:03:59 Intraday data recording state for symbol ZN-201509-CBOT is set to download pending. | 2015-06-05 09:03:59 HD Request # 2 | Requesting Intraday data. Start Date-Time: 2015-06-05 09:03:51. Record interval: 0. Symbol: YM-201506-CBOT | 2015-06-05 09:04:00 HD Request # 2 | Decompressing data. | 2015-06-05 09:04:00 Socket (2) | Shutdown and closed. | 2015-06-05 09:04:00 The network socket for historical data has been closed. | 2015-06-05 09:04:00 HD Request # 2 | Historical data for YM-201506-CBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-06-05 09:04:00 HD Request # 2 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YM-201506-CBOT | 2015-06-05 09:04:00 HD Request # 2 | Intraday download COMPLETE for YM-201506-CBOT. Completion time: 1s. Unique request ID: 1 | 2015-06-05 09:04:00 Removed historical data download ID 1 | 2015-06-05 09:04:00 HD Request # 3 | Downloading Intraday chart data for NTCK-NYSE to the file NTCK-NYSE.scid. Service: statscalc | 2015-06-05 09:04:00 HD Request # 3 | Download start Date-Time: 2015-06-05 09:03:52.0 | 2015-06-05 09:04:00 HD Request # 3 | Using server: ds3.sierracharts.com port 10149 | 2015-06-05 09:04:00 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-06-05 09:04:00 Socket (3) | Connected. | 2015-06-05 09:04:00 HD Request # 3 | Sending historical data logon request message. | 2015-06-05 09:04:00 HD Request # 3 | Requesting Intraday data. Start Date-Time: 2015-06-05 09:03:52. Record interval: 0. Symbol: NTCK-NYSE | 2015-06-05 09:04:00 HD Request # 3 | Decompressing data. | 2015-06-05 09:04:00 HD Request # 3 | Receiving Intraday data for NTCK-NYSE starting at 2015-06-05 09:03:52 | 2015-06-05 09:04:00 HD Request # 3 | Timestamp of first Intraday data file record written: 2015-06-05 09:03:53 | 2015-06-05 09:04:00 Socket (3) | Shutdown and closed. | 2015-06-05 09:04:00 The network socket for historical data has been closed. | 2015-06-05 09:04:00 HD Request # 3 | Historical data for NTCK-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-06-05 09:04:00 HD Request # 3 | Received 25 records from 2015-06-05 09:03:52 to 2015-06-05 09:04:17 (25.0 seconds) and wrote 24 records for NTCK-NYSE | 2015-06-05 09:04:00 HD Request # 3 | Intraday download COMPLETE for NTCK-NYSE. Completion time: 0s. Unique request ID: 2 | 2015-06-05 09:04:00 Removed historical data download ID 2 | 2015-06-05 09:04:00 HD Request # 4 | Downloading Intraday chart data for ZN-201509-CBOT to the file ZN-201509-CBOT.scid. Service: ttamp | 2015-06-05 09:04:00 HD Request # 4 | Download start Date-Time: 2015-06-05 09:03:52.0 | 2015-06-05 09:04:00 HD Request # 4 | Using server: ttamp.sierracharts.com port 10149 | 2015-06-05 09:04:00 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-06-05 09:04:00 Socket (4) | Connected. | 2015-06-05 09:04:00 HD Request # 4 | Sending historical data logon request message. | 2015-06-05 09:04:00 HD Request # 4 | Requesting Intraday data. Start Date-Time: 2015-06-05 09:03:52. Record interval: 0. Symbol: ZN-201509-CBOT | 2015-06-05 09:04:00 HD Request # 4 | Decompressing data. | 2015-06-05 09:04:00 Socket (4) | Shutdown and closed. | 2015-06-05 09:04:00 The network socket for historical data has been closed. | 2015-06-05 09:04:00 HD Request # 4 | Historical data for ZN-201509-CBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-06-05 09:04:00 HD Request # 4 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZN-201509-CBOT | 2015-06-05 09:04:00 HD Request # 4 | Intraday download COMPLETE for ZN-201509-CBOT. Completion time: 0s. Unique request ID: 3 | 2015-06-05 09:04:00 Removed historical data download ID 3 | 2015-06-05 09:04:00 HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-06-05 09:04:01 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-06-05 09:04:01 AMP/TTNet | Connecting. | 2015-06-05 09:04:01 TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-06-05 09:04:01 TT FIX Data socket (5) | Connected. | 2015-06-05 09:04:01 TT FIX Data: Sending the Logon message. | 2015-06-05 09:04:02 TT FIX Data: Connected. | 2015-06-05 09:04:02 TT FIX Trading | Connecting to 12.41.48.53. Port10500 | 2015-06-05 09:04:02 TT FIX Trading socket (6) | Connected. | 2015-06-05 09:04:02 TT FIX Trading: Sending the Logon message. | 2015-06-05 09:04:03 TT FIX Trading: Connected. | 2015-06-05 09:04:03 AMP/TTNet | Connected. | 2015-06-05 09:04:03 AMP/TTNet | Starting real-time market data updates for: YM-201506-CBOT. ID: 1 | 2015-06-05 09:04:03 Translating exchange from CBOT to CME for symbol YM-201506-CBOT | 2015-06-05 09:04:03 Requesting market data for YM-201506-CBOT. Depth levels: 1 | 2015-06-05 09:04:03 Intraday data recording state for symbol YM-201506-CBOT is set to download pending. | 2015-06-05 09:04:03 HD Request # 5 | Downloading Intraday chart data for YM-201506-CBOT to the file YM-201506-CBOT.scid. Service: ttamp | 2015-06-05 09:04:03 HD Request # 5 | Download start Date-Time: 2015-06-05 09:03:51.0 | 2015-06-05 09:04:03 HD Request # 5 | Using server: ttamp.sierracharts.com port 10149 | 2015-06-05 09:04:03 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-06-05 09:04:03 TT Gateway Status: Price server for the CME exchange is Open | 2015-06-05 09:04:03 TT Gateway Status: Order server for the CME exchange is Open | 2015-06-05 09:04:03 TT Gateway Status: Fill server for the CME exchange is Open | 2015-06-05 09:04:03 TT Gateway Status: Price server for the Eurex-B exchange is Open | 2015-06-05 09:04:03 TT Gateway Status: Order server for the Eurex-B exchange is Open | 2015-06-05 09:04:03 TT Gateway Status: Fill server for the Eurex-B exchange is Open | 2015-06-05 09:04:03 TT Gateway Status: Price server for the ICE_IPE exchange is Open | 2015-06-05 09:04:03 TT Gateway Status: Order server for the ICE_IPE exchange is Open | 2015-06-05 09:04:03 TT Gateway Status: Fill server for the ICE_IPE exchange is Open | 2015-06-05 09:04:03 TT Gateway Status: Price server for the TTSIM exchange is Open | 2015-06-05 09:04:03 TT Gateway Status: Order server for the TTSIM exchange is Open | 2015-06-05 09:04:03 TT Gateway Status: Fill server for the TTSIM exchange is Open | 2015-06-05 09:04:03 Socket (7) | Connected. | 2015-06-05 09:04:03 HD Request # 5 | Sending historical data logon request message. | 2015-06-05 09:04:03 SC Market Stats | Starting real-time market data updates for: NTCK-NYSE. ID: 2 | 2015-06-05 09:04:03 SC Market Stats | Connecting to the server ds5.sierracharts.com. Port 443 | 2015-06-05 09:04:03 Intraday data recording state for symbol NTCK-NYSE is set to download pending. | 2015-06-05 09:04:03 HD Request # 5 | Requesting Intraday data. Start Date-Time: 2015-06-05 09:03:51. Record interval: 0. Symbol: YM-201506-CBOT | 2015-06-05 09:04:03 AMP/TTNet | Starting real-time market data updates for: ZN-201509-CBOT. ID: 3 | 2015-06-05 09:04:03 Translating exchange from CBOT to CME for symbol ZN-201509-CBOT | 2015-06-05 09:04:03 Requesting market data for ZN-201509-CBOT. Depth levels: 1 | 2015-06-05 09:04:03 Intraday data recording state for symbol ZN-201509-CBOT is set to download pending. | 2015-06-05 09:04:03 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-06-05 09:04:03 HD Request # 5 | Decompressing data. | 2015-06-05 09:04:03 HD Request # 5 | Receiving Intraday data for YM-201506-CBOT starting at 2015-06-05 09:03:51 | 2015-06-05 09:04:03 HD Request # 5 | Timestamp of first Intraday data file record written: 2015-06-05 09:03:54 | 2015-06-05 09:04:03 Socket (7) | Shutdown and closed. | 2015-06-05 09:04:03 The network socket for historical data has been closed. | 2015-06-05 09:04:03 HD Request # 5 | Received 35 records from 2015-06-05 09:03:51 to 2015-06-05 09:04:16 (25.0 seconds) and wrote 34 records for YM-201506-CBOT | 2015-06-05 09:04:03 HD Request # 5 | Intraday download COMPLETE for YM-201506-CBOT. Completion time: 0s. Unique request ID: 4 | 2015-06-05 09:04:03 Removed historical data download ID 4 | 2015-06-05 09:04:03 Real-time Intraday chart data file updates started for YM-201506-CBOT | 2015-06-05 09:04:03 Socket (8) | Connected. | 2015-06-05 09:04:03 SC Market Stats | Connected to server. | 2015-06-05 09:04:03 SC Market Stats | Sending logon request message. | 2015-06-05 09:04:03 HD Request # 6 | Downloading Intraday chart data for NTCK-NYSE to the file NTCK-NYSE.scid. Service: statscalc | 2015-06-05 09:04:03 HD Request # 6 | Download start Date-Time: 2015-06-05 09:04:17.0 | 2015-06-05 09:04:04 HD Request # 6 | Using server: ds4.sierracharts.com port 10149 | 2015-06-05 09:04:04 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-06-05 09:04:04 Socket (9) | Connected. | 2015-06-05 09:04:04 HD Request # 6 | Sending historical data logon request message. | 2015-06-05 09:04:04 HD Request # 6 | Requesting Intraday data. Start Date-Time: 2015-06-05 09:04:17. Record interval: 0. Symbol: NTCK-NYSE | 2015-06-05 09:04:04 HD Request # 6 | Decompressing data. | 2015-06-05 09:04:04 HD Request # 6 | Receiving Intraday data for NTCK-NYSE starting at 2015-06-05 09:04:17 | 2015-06-05 09:04:04 HD Request # 6 | Timestamp of first Intraday data file record written: 2015-06-05 09:04:19 | 2015-06-05 09:04:04 Socket (9) | Shutdown and closed. | 2015-06-05 09:04:04 The network socket for historical data has been closed. | 2015-06-05 09:04:04 HD Request # 6 | Received 5 records from 2015-06-05 09:04:17 to 2015-06-05 09:04:22 (5.0 seconds) and wrote 4 records for NTCK-NYSE | 2015-06-05 09:04:04 HD Request # 6 | Intraday download COMPLETE for NTCK-NYSE. Completion time: 1s. Unique request ID: 5 | 2015-06-05 09:04:04 Removed historical data download ID 5 | 2015-06-05 09:04:04 Real-time Intraday chart data file updates started for NTCK-NYSE | 2015-06-05 09:04:04 SC Market Stats | Server Name: SC Real-Time Server. | 2015-06-05 09:04:04 SC Market Stats | Server protocol version: 6. Client protocol version: 5. There is a protocol mismatch! | 2015-06-05 09:04:04 SC Market Stats | Successfully connected. | 2015-06-05 09:04:04 Intraday data recording state for symbol NTCK-NYSE is set to download pending. | 2015-06-05 09:04:04 SC Market Stats | Restarting real-time data updates for symbol: NTCK-NYSE | 2015-06-05 09:04:04 HD Request # 7 | Downloading Intraday chart data for ZN-201509-CBOT to the file ZN-201509-CBOT.scid. Service: ttamp | 2015-06-05 09:04:04 HD Request # 7 | Download start Date-Time: 2015-06-05 09:03:52.0 | 2015-06-05 09:04:05 HD Request # 7 | Using server: ttamp.sierracharts.com port 10149 | 2015-06-05 09:04:05 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-06-05 09:04:05 Socket (10) | Connected. | 2015-06-05 09:04:05 HD Request # 7 | Sending historical data logon request message. | 2015-06-05 09:04:05 HD Request # 7 | Requesting Intraday data. Start Date-Time: 2015-06-05 09:03:52. Record interval: 0. Symbol: ZN-201509-CBOT | 2015-06-05 09:04:05 HD Request # 7 | Decompressing data. | 2015-06-05 09:04:05 HD Request # 7 | Receiving Intraday data for ZN-201509-CBOT starting at 2015-06-05 09:03:52 | 2015-06-05 09:04:05 HD Request # 7 | Timestamp of first Intraday data file record written: 2015-06-05 09:03:53 | 2015-06-05 09:04:05 Socket (10) | Shutdown and closed. | 2015-06-05 09:04:05 The network socket for historical data has been closed. | 2015-06-05 09:04:05 HD Request # 7 | Received 516 records from 2015-06-05 09:03:52 to 2015-06-05 09:04:22 (30.0 seconds) and wrote 515 records for ZN-201509-CBOT | 2015-06-05 09:04:05 HD Request # 7 | Intraday download COMPLETE for ZN-201509-CBOT. Completion time: 0s. Unique request ID: 6 | 2015-06-05 09:04:05 Removed historical data download ID 6 | 2015-06-05 09:04:05 Real-time Intraday chart data file updates started for ZN-201509-CBOT | 2015-06-05 09:04:05 HD Request # 8 | Downloading Intraday chart data for NTCK-NYSE to the file NTCK-NYSE.scid. Service: statscalc | 2015-06-05 09:04:05 HD Request # 8 | Download start Date-Time: 2015-06-05 09:04:22.0 | 2015-06-05 09:04:05 HD Request # 8 | Using server: ds3.sierracharts.com port 10149 | 2015-06-05 09:04:05 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-06-05 09:04:05 Socket (11) | Connected. | 2015-06-05 09:04:05 HD Request # 8 | Sending historical data logon request message. | 2015-06-05 09:04:05 HD Request # 8 | Requesting Intraday data. Start Date-Time: 2015-06-05 09:04:22. Record interval: 0. Symbol: NTCK-NYSE | 2015-06-05 09:04:05 HD Request # 8 | Decompressing data. | 2015-06-05 09:04:05 HD Request # 8 | Receiving Intraday data for NTCK-NYSE starting at 2015-06-05 09:04:22 | 2015-06-05 09:04:05 Socket (11) | Shutdown and closed. | 2015-06-05 09:04:05 The network socket for historical data has been closed. | 2015-06-05 09:04:05 HD Request # 8 | Received 1 record from 2015-06-05 09:04:22 to 2015-06-05 09:04:22 (0.0 seconds) and wrote 0 records for NTCK-NYSE | 2015-06-05 09:04:05 HD Request # 8 | Timestamp of first Intraday data file record written: 2015-06-05 09:04:23 | 2015-06-05 09:04:05 Added 5 Time and Sales records to Intraday data file for NTCK-NYSE after download. | 2015-06-05 09:04:05 HD Request # 8 | Intraday download COMPLETE for NTCK-NYSE. Completion time: 0s. Unique request ID: 7 | 2015-06-05 09:04:05 Removed historical data download ID 7 | 2015-06-05 09:04:05 Real-time Intraday chart data file updates started for NTCK-NYSE | 2015-06-05 09:04:05 Error loading custom studies DLL: C:\SierraChart\Data\StudyCrossMarker.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\StudyCrossMarker.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\scanABVDT_b3.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\scanABVDT_b3.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\StudyCrossMarker.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\StudyCrossMarker.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\scanABVDT_b3.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\scanABVDT_b3.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\StudyCrossMarker.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\StudyCrossMarker.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\scanABVDT_b3.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\scanABVDT_b3.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\StudyCrossMarker.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\StudyCrossMarker.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\scanABVDT_b3.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\scanABVDT_b3.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\StudyCrossMarker.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\StudyCrossMarker.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\scanABVDT_b3.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\scanABVDT_b3.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\StudyCrossMarker.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\StudyCrossMarker.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\scanABVDT_b3.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Error loading custom studies DLL: C:\SierraChart\Data\scanABVDT_b3.dll. Windows error code 126: The specified module could not be found. | 2015-06-05 09:04:07 * Requesting market depth updates for: YM-201506-CBOT if supported. | 2015-06-05 09:04:08 Translating exchange from CBOT to CME for symbol YM-201506-CBOT | 2015-06-05 09:04:08 Translating exchange from CBOT to CME for symbol YM-201506-CBOT | 2015-06-05 09:04:08 Requesting market data for YM-201506-CBOT. Depth levels: 1 | 2015-06-05 09:04:08 Requesting market depth updates for: ZN-201509-CBOT if supported. | 2015-06-05 09:04:08 Translating exchange from CBOT to CME for symbol ZN-201509-CBOT | 2015-06-05 09:04:08 Translating exchange from CBOT to CME for symbol ZN-201509-CBOT | 2015-06-05 09:04:08 Requesting market data for ZN-201509-CBOT. Depth levels: 1 | 2015-06-05 09:04:08 The advanced custom study SierraChartStudies.scsf_1_p is made for version 1261 or higher of Z. | 2015-06-05 09:13:17 * |
[2015-06-05 15:17:00] |
Hi , I fixed window error 126 , and successfully downloaded new 1261,so it was my computer issue only. Thank you for your time support |
