Date/Time: Sun, 04 Oct 2026 08:45:12 +0000
Confusing Levels
View Count: 1182
| [2015-06-04 16:50:33] |
| User80120 - Posts: 6 |
I plotted on the chart Previous Week High, Low & Mid levels & the same for the Month, However they are not accurate at all in addition in changes completely depending how many days you put on the chart to load !? I would appreciate if someone can help me ASAP. Morris Date Time Of Last Edit: 2015-06-04 18:37:17
| [2015-06-04 18:36:55] |
What specific study are you using and what are the settings of it for one of the instances?
| [2015-06-04 19:00:36] |
I'm using "Daily OHLC" and then setting on the drop down menu "days" for the Daily , "weeks" for the weekly and "months" for the monthly . However as I stated before those levels keep on changing depending how many days I ask the chart to load |
| [2015-06-09 14:56:54] |
Hello, I'm still waiting for a proper reply, thanks |
| [2015-06-09 16:41:28] |
We apologize, this was overlooked. You need to use the Period OHLC-Variable Period study. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s294 Also, the chart bars themselves must not exceed 1 day per bar themselves. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
