Date/Time: Sun, 22 Dec 2024 16:37:54 +0000
Tickchart in DOM
View Count: 952
[2015-06-04 11:41:50]
nicktrader - Posts: 715
Is it possible to see a tickchart in the DOM as in the DOM on the right hand sight shown?
I tried it with "Study/ Price Overlay" but the result isn't the same as on the other DOM. The graph in the other DOM shows peaks and valleys. Esp. these issues are very helpful.
Many thanks
imageTickchart in DOM.png / V - Attached On 2015-06-04 11:34:44 UTC - Size: 130.96 KB - 373 views
[2015-06-04 18:41:44]
The general way to accomplish this is to use a standard chart configured as you require and enable the Chart DOM on that chart:
https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#ChartDOM
