Date/Time: Thu, 26 Dec 2024 10:10:52 +0000
8H button on toolbar
View Count: 871
[2015-06-04 10:10:52] |
User27542 - Posts: 20 |
I like using 8 hour intraday charts, but at present there does not appear to be an 8H button that I can add to the toolbar. I know I can just type 480 for these, but it would be nice for toggling quickly between different time frames. Is there any way I can add one? With thanks for any help you can give. |
[2015-06-04 11:30:09] |
Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeToolbar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-04 12:41:47] |
Brilliant. Thanks.
