Date/Time: Thu, 26 Dec 2024 19:58:35 +0000
Need help understanding on how to transfer data to excel
View Count: 842
[2015-06-03 21:21:06] |
User48557 - Posts: 138 |
I have a friend who has excel but does not have sierra chart. I am trying to send him Crude oil data since June 1st 2012 so we can do some analysis. Can i just drag the Crude oil data from the ''DATA'' folder from my hard drive ? Then email it to my friend
[2015-06-04 00:14:30] |
It depends. Are you referring to an Intraday chart or a Historical Daily chart?
[2015-06-04 01:05:59] |
1 minute Intraday chart.
[2015-06-04 01:17:49] |
In this case, you first need to export the data to a text format. This is explained here: http://www.sierrachart.com/index.php?page=doc/doc_ImportExport.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
