Date/Time: Thu, 26 Dec 2024 20:19:27 +0000
Problem with Historical daily data with CTS data feed
View Count: 795
[2015-06-03 04:50:49] |
User64630 - Posts: 19 |
Hello, I ask to load 4000 days of historical daily but i have only six months. I attach screenshots to show you the settings that I put. Regards. Date Time Of Last Edit: 2015-06-03 05:00:38
2015-06-03_06h37_40.png / V - Attached On 2015-06-03 04:50:03 UTC - Size: 54.27 KB - 317 views 2015-06-03_06h37_57.png / V - Attached On 2015-06-03 04:50:09 UTC - Size: 47.99 KB - 327 views 2015-06-03_06h55_20.png / V - Attached On 2015-06-03 04:56:16 UTC - Size: 47.47 KB - 312 views 2015-06-03_07h00_13.png / V - Attached On 2015-06-03 05:00:28 UTC - Size: 55.22 KB - 298 views |
[2015-06-03 09:39:07] |
Remove "CL" from the Trade and Current Quote Symbol box in Chart >> Chart Settings. If there still is a problem re-download the data following the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
