Date/Time: Thu, 26 Dec 2024 19:57:29 +0000
data loading
View Count: 779
[2015-06-02 17:56:39]
madra - Posts: 109
lately data loading from ib brokers is inordinately slow for intraday symbols. Are there any parameters that I should look at to sped up the process?
Thank you
Charlie
[2015-06-02 21:32:23]
Follow the instructions here:
https://www.sierrachart.com/index.php?page=doc/IB.php#SlowDownloading
Depending upon the particular symbols you are tracking, it could also make a dramatic difference if you change to Sierra Chart service package 3 which will use the Sierra Chart Historical Data service. The speed increase will be massive. Like 100 times or more faster.
