Date/Time: Thu, 26 Dec 2024 20:02:58 +0000
Questions about Sierra Chart Spreadsheet Study
View Count: 776
[2015-06-02 15:47:08] |
User47066 - Posts: 3 |
Hello, I am wondering which would be more efficient in backtesting. -to have multiple columns of formulae with dependencies to call the entry or - to have all the formula nested in the buy entry column ( all of the formula are nested in each other) All the best, Alex |
[2015-06-02 15:53:56] |
Using the fewer number of columns should should reduce processing, but we will check on this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-02 15:54:11
