Date/Time: Tue, 22 Sep 2026 23:59:14 +0000
Chart Issue
View Count: 1256
| [2015-06-02 04:00:18] |
i'm using SC Historical Data but i cannot properly display th echart for B6 (cable from cme) and AUM http://www.sierrachart.com/image.php?l=1433206827147.png http://www.sierrachart.com/image.php?l=14332072485.png Please how can i solve my problem? How can download data for USDJPY futures? Sierra Chart Support |
| [2015-06-03 18:36:02] |
Are you sure that you want futures data? Or do you want data for the cash Forex market? You have to be using the symbol for actively traded futures market, and you also need to enable the Continuous Futures Contract option: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-06-10 19:21:19] |
| User567321 - Posts: 1 |
Please, How can download data for USDJPY futures from SC historical data? I downloaded J6M15, inverted the chart with '1 divided by price' study but how can i change the price from 1.2440 to 124.40 (example) ? Thank you Date Time Of Last Edit: 2015-06-10 19:39:10
| [2015-06-11 05:10:35] |
Use the symbol ^USDJPY. You can also adjust the Historical and Real-time Price Multipliers in Chart >> Chart Settings >> Advanced Settings 2. Set them to 100. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
