Date/Time: Thu, 24 Sep 2026 19:26:16 +0000
Windows 10
View Count: 2182
| [2015-06-01 23:39:34] |
| User32803 - Posts: 18 |
Do you have a time frame for when you will include Windows 10 as part of the acceptable operating systems? A beta version of Windows 10 is available for me but I don't want to try it until it is compatible with Sierra Chart.
| [2015-06-02 00:21:40] |
We are not aware of anything special that has to be done for Sierra Chart work on Windows 10. So Sierra Chart should run fine on Windows 10.
