Date/Time: Sat, 19 Sep 2026 08:36:47 +0000
FX Data with Sierra Data Feed on CQG
View Count: 1400
[2015-06-01 18:19:15]
Cavalry3162 - Posts: 523
i dont know if this was asked before, i was unable to phrase a proper forum search and did not come up with a result.
i am on sierrachart data feed via CQG / deepdiscounttrading and want to chart an FX symbol (EURUSD). as i can not trade FX via this broker, there is no such symbol available.
is there a way to get EURUSD data in this setup?
thank you in advance,
Andreas
[2015-06-01 20:27:15]
Yes you can do this. Install another copy of Sierra Chart on your system following the instructions here:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
And set it to use the Sierra Chart Real-time and Historical Forex/CFD Data service:
Sierra Chart Real Time and Historical Forex and CFD Data Service
[2015-06-01 20:43:52]
thank you!
just to make sure i am not violating the rules here, i've one instance of sierrachart already running on 2 computers. if i start a (3rd) instance on one of these pc's (so that there is running 1 instance on 1 pc and 2 instances on the other pc), that would be OK for you guys?
thanks,
Andreas
[2015-06-01 21:47:21]
Yes. This is acceptable. There is no limit to the number of instances of Sierra Chart which can be installed and used on a computer at the same time.
