Date/Time: Wed, 09 Sep 2026 22:22:36 +0000
[User Discussion] - Help needed with custom indicator
View Count: 1383
[2015-06-01 09:03:31]
Sebastian_M - Posts: 70
Hello expert coders,
The image represents what I am trying to do.
I drew somw of the code fom here.
http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_scInputs.html
I am struggling to build this file. I know I am missing an initializer, but do not have the experience to solve it.
-- Starting build of Custom Studies Source files: Seb_TrendpointHigh3.cpp. -- 09:42:45
"C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\Seb_TrendpointHigh3.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -o "C:\SierraChart\Data\Seb_TrendpointHigh3.dll"
C:\SierraChart\ACS_Source\Seb_TrendpointHigh3.cpp:7:1: error: expected initializer before 'SCInputRef'
SCInputRef Length = sc.Input[0];
C:\SierraChart\ACS_Source\Seb_TrendpointHigh3.cpp:8:1: error: expected unqualified-id before '{' token
-- End of Build -- 09:42:46
Would appreciate any help
Regards Sebastian
Date Time Of Last Edit: 2015-06-02 09:11:14
imageExample_high_lows.jpg / V - Attached On 2015-06-01 08:58:55 UTC - Size: 179.51 KB - 462 views
[2015-06-01 09:49:36]
The code needs to be like this in the beginning:
#include "sierrachart.h"
SCDLLName("Seb_TrendpointHigh3")
SCSFExport scsf_Seb_TrendpointHigh3(SCStudyGraphRef sc)
if (sc.SetDefaults)
Date Time Of Last Edit: 2015-06-01 09:51:43
[2015-06-01 19:51:48]
Thank you support,
But I still do not have the horizontal lines into the future as in the chart?
Is this possible?
Thank you in advance
imageExample_high_lows2.jpg / V - Attached On 2015-06-01 19:50:47 UTC - Size: 181.46 KB - 467 views
[2015-06-01 20:30:59]
Refer to this sc.Subgraph[] member:
ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].ExtendedArrayElementsToGraph
If this does not answer your question, then this is outside the scope of our support.
Date Time Of Last Edit: 2015-06-01 20:31:43
[2015-06-01 21:07:49]
Hi support,
could not get it to work.
Thanks anyway
[2015-06-01 21:50:34]
The only thing that we can add is that you need to set the elements of a sc.Subgraph[].Data[] array to the values of the line where you want to see the line. This page should help:
http://www.sierrachart.com/index.php?page=doc/doc_ACS_ArraysAndLooping.html
Date Time Of Last Edit: 2015-06-01 23:01:37
[2015-06-01 22:51:06]
SgtJ - Posts: 154
I can likely help you. I can pm you on bigmikes if available or post your email if interested.
[2015-06-02 08:33:51]
Hi SgtJ
my email is:
Email removed
until 21:00 BST London time 02/06/2015 when I will delete it from this post.
Regards Seb
Date Time Of Last Edit: 2015-06-02 13:11:00
[2015-06-02 12:46:08]
SgtJ - Posts: 154
Ok, got it. You can delete it asap.
