Date/Time: Sun, 13 Sep 2026 21:06:28 +0000
using arrow up/down as color bar alert draw style
View Count: 2091
[2015-05-31 18:55:29]
Seanz - Posts: 17
Have set up a color bar alert study and would like to use the Arrow Up or Arrow Dn over or under the bar where signal occurs instead of 'coloring the bar'. However, the arrows appear at either the top or bottom of the chart rather than just above or below the signal bar? Could someone please tell me how to fix this? btw, if I change the 'draw style' to Point on H or Point on L it works fine but I just can't get the arrow up/dn to draw in the same way.
Thanks for your help.
[2015-05-31 19:03:04]
Sawtooth - Posts: 4352
Set the Output When Condition True to Use Input Data, then set the Input Data to the location you want.
