Date/Time: Sun, 22 Dec 2024 14:10:33 +0000
Continous Drawing Mode
View Count: 1006
[2015-05-31 10:37:16] |
krisnara - Posts: 7 |
Hi, How do I disable the "Continous Drawing mode" ? I looked for the options but unable to find it easily. Also is there an option to display a price line where the current price is inorder to visually make it easy to track movement of price? Thanks |
[2015-06-01 20:53:31] |
We do not know what Continuous Drawing Mode is referring to. Use the Current Price Line study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s123 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-02 03:02:12] |
Thanks for the reply. Here is what I meant by Continuous drawing mode. When I select a draw tool such as horizontal line , I want the drawing mode to on only once for drawing the line and then no more until selected again.But here it in every click i do a line is being drawn.I want to disable this automatic drawing..that is what i meant when I said continous drawing mode. |
[2015-06-02 04:32:42] |
Therefore, you need to set the option to change to the Pointer tool after a single tool use. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#SettingtheDefaultTool Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
