Date/Time: Sun, 22 Dec 2024 14:19:45 +0000
NYSE Tick and NYSE A/D Line
View Count: 1575
[2015-05-31 05:32:56] |
User463662 - Posts: 50 |
On my chart, using Rithmic data, I am able to get historical data to load for quite a few years back on all my charts except the NYSE TICK chart and NYSE A/D Line. I checked and made sure I have the most current symbols selected. I attempted to load 1500 days back, but those charts will only go back to April 2014. I read through the downloading intraday data support information but didn't get it to work for me using that information.
Date Time Of Last Edit: 2015-05-31 05:33:40
[2015-06-01 21:00:14] |
The data is available back to February 2014 for the Sierra Chart calculated market statistics. If it is critical to get market statistics earlier than this, you can use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service The symbols are different and can be found here: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=MarketStats Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
