Date/Time: Sun, 22 Dec 2024 14:37:21 +0000
Alerts Manager Window does not open
View Count: 788
[2015-05-29 01:07:43] |
User930315 - Posts: 55 |
I'm attempting to open the Alerts Manager Window on my laptop and it does not come up. I copied the Sierra Chart configuration from my multiple monitor desktop computer and suspect the window may be opening off screen on my laptop, but I don't see a separate window in the task bar either. If it is opening off screen should it show up in the task bar? Is there a way to reset the default Alerts Manager window position? I'm running Windows 7 64-bit. Thanks |
[2015-05-29 03:17:17] |
Select Window >> Reset Windows and try again.
